Should there be a steady pee stream or just intermitent weak spray during idle?
I imzame Cadet Joined Apr 29, 2011 Messages 11 May 2, 2011 #1 Should there be a steady pee stream or just intermitent weak spray during idle?
M mars bar Petty Officer 1st Class Joined Nov 30, 2008 Messages 395 May 2, 2011 #2 Re: 1964 90 hp johnson - I just want to be sure about the water stream imzame said: Should there be a steady pee stream or just intermitent weak spray during idle? Click to expand... I have a 1972 esl 50 hp and I have a steady stream at idle. Mind you I had to put in a tell tale pee line.
