1964 90 hp johnson - There is alotta smoke coming from the bottom of the lower unit.
imzame
Shouldnt the smoke be comming out the exhaust hole? It is comming out the hole by the water inlet..
tx1961whaler
Re: 1964 90 hp johnson - There is alotta smoke coming from the bottom of the lower un
The main exhaust outlet is under water. The exhaust relief valve is in the midsection, where you can see some of the water spray out with the exhaust.
