Re: My boat has hard time getting on a plane
As was said, you need a fast start--opposite a car and not doing a 'jackrabbit" start.
Your 150 on a 19 should have no trouble getting up. As was said, start with the motor down, but be careful because sometimes this will make the bow dig in and the boat veer one side or the other (happens worse with tabs).
I am using tabs on a 21', for the first time in about 40 years of boating. I like them and say they are important on a larger boat. Ona 19 I'd call it a nice option to have but not necessary.
Try putting your passengers in the bow when you take off, too--or certainly get them out of the stern. It's hard to get a 19 to behave with people in the stern.
Also be sure your boat is properly propped and running correctly--you may have dropped a cylinder and not know it. I'd start by seeing what you do at WOT*, compare your RPM and MPH on a GPS. EIEIO. When you get up there, watch the results as you trim the motor up--speed will magically increase, until you get to the point where it cavitates (catches air in the prop). You'll hear it.
Congrats on the new boat! It's a good rig.
*wide open throttle
