A.Hoj
- May 24, 2006
- 39
I have a 1998 Force 90 hp. The carbs leak fuel when I shut the motor off, and even worse when I tilt the motor up. Also it stalls after a long ride and I back it down to Idle. I'm assuming the carbs need to be rebuilt. Can someone help me out with the correct part # for the rebuild kit? the serial number on the motor is 0E326317, and any other important info I might not find in the shop manual. I also noticed that they leak fuel from a little hole on the side of the carb. Not sure if this is caused by a bad needle valve or not.
Thanks.
Thanks.
