Re: Water in the crankcase oil
How much water? Is it over the fill line of dipstick? Do you do a lot of trolling or idling? Stuck open t-stats and extended low speed operation makes engine build condensation in crankcase. If oil level changes very little and oil is discolored this is likely cause,if your getting a lot of water it could be several things....
