Moneypitt1
- May 1, 2011
- 3
Having starter problems with 1988 165 mercruiser engine. Just clicks when you turn the key
This is what I have done :
New re manufactured starter
New interstate battery 1000 cranking amps
New starter solenoid
New battery cables
Plugs are out and the engine turns freely with pry bar on flywheel
New Gimbel bearing
New bellows done at end of season last year
All electrical connections removed and cleaned
When I turn the key the starter just clicks (HELP)
50 Amp fuse is solid and will not push in(?) Is this correct?
Thanks Moneypitt1
New battery cables
New Gimbel bearing
Thanks Moneypitt1
