Re: need points gap for a 1964 90hp Johnson Meteor. Anyone help?
Not to bud in on Tim here, but you are replacing those points correct, not just regapping them? When you do ensure they are EXTREMELY clean, no fingerprints, etc. Dont use sanpaper on them either, it wont file them square, and you wont get good spark. It also leaves grit on the points, disturbing contact. Points file only or replace. I clean mine with acetone after Im done adjusting, and test with a meter to guarantee they are opening and closing when they should. If you want help with this, and have access to a meter, let us know.
As far as will it run better, heck ya.
