I'm going to do some research, but thought I would ask in case someone could answer quicker than me searching around I've got a 1981 25hp Johnson. It's starting to get a bit of a knock at WOT...probably needs a rebuild. Was wondering if a 1979 Evinrude would be interchangeable as far as the powerhead? I found a '79 Evinrude 25hp that has a bad lower unit for cheap. Was wondering if I could swap some parts. Any info would be great. Thank you.
