Hi all hoping someone can shed some light for me as i have never owned a yamaha or a 4stroke before.
When i start it, it runs lovely and sounds smooth and quite, but there is only a spray of water coming from the outlet at the back not a constant stream.
I have had the gearbox off and the impellor looks fine as does the gasket, there was a small sign of salt but not much.
I also noticed when running i cant get it in gear, i know the gearbox is free as when i took it off i checked it too make sure the gears engaged correctly, the lever does move slightly but it seems there is something blocking it or a safety catch? I dont think the lever is seized as the engine i was told was serviced last october.
Any advice and pointers will be greatly received.
jamie
jamie
