runs wide open
bj gra
1978 mercury 1150 shoots gas out of top carberator and runs wide open until it floods itself out:confused: i replaced floats but still does it
bj gra
Re: runs wide open
yes if i unhook the gas it runs high idle then runs normal until its out of gas
bj gra
Re: runs wide open
would it be the carb that shoots the gas out that has the problem
Wingedwheel
Re: runs wide open
Why did you replace the floats? Was there a problem and you thought that was it? Did you do anything else to the carb when you had it apart?
bj gra
Re: runs wide open
the float had cracks and was stuck so i thought that was the problem
Wingedwheel
Re: runs wide open
OK but did you do anything else to the carb when you had it apart?
M
Maxz695
Guest
Re: runs wide open
check your linkage. and the butterfly in the carb to make sure it,s closing all the way.
bj gra
Re: runs wide open
when u start it it runs wide open then it starts to shoot gas out of the top carb then it seems as though it floods out and when you pump the ball to long it shoots gas out of the top carb also
Silvertip
Re: runs wide open
You aren't answering questions. Did you properly ADJUST the foat. I can almost guarantee it would not be correct out of the box. I shouldn't have to ask, but did you make sure the inlet needle was in place when you reassembled the carb? The problem is that the float is not shutting off the fuel flow. Either the float is installed wrong or not adjusted correctly, or the inlest needle is missing or installed wrong.
