KingNeptune
- Apr 29, 2011
- 4
Just changed out the impeller on my good ol' Tohatsu 90TLDI and reassembled it and now it does not go into gear.
Now before you say I haven't reconnected the gearshift rod with the small pin, I have.
It appears the gearshift mechanism has disconnected or broken somewhere just under the engine when I was working on the lower leg.
When I move the throttle handle there is movement down to the control arm on the engine, but there is no movement down below near the prop.
I am hoping someone can tell me this can be easily fixed, but I suspect it is a big job.
I also have water pumping out everywhere except the telltale, and I was hoping it is possible to clear the upper water pathway around the injector pump easily?
The engine also appears to have carbon buildup and has been idling rough lately, I am going to try a can of the decarbon spray once she is going properly again, anyone had much luck with these sprays?
