My 2005 Johnson 150 is giving me fits. When I first launch, everything is great. It idles fine, takes off fine, runs fine. But once I have ran it and it gets up to good temp and I shut down to fish, it keeps dying when I start it back up, then I get it running and it dies when I put it in gear. The only thing I can do is get in the throttle and idle it up a little and put it in gear to take off. I don't mean a lot, just enough to keep it running. Now once it is going, it runs like a champ. Does this sound like an adjustment issue or the TPS? Thanks for any advice offered. Also, the bulb was losing pressure so I changed it thinking the check valve might be leaking back but the new one does the same thing. So I looked for ANY sign of a leak. Removed the cowl and found no leakage from carburators or lines, no fuel in bilge, no shean on water, and no fuel at transom.
