1998 Johnson 25 hp - won't go over 2500 rpm
Hometime
I have a 1998 , Johnson , 25 h.p , I can not get it over 2500 rpms.. Any suggestions, Thank You..
Cofe
Re: 1998 Johnson 25 hp - won't go over 2500 rpm
Is it tiller or remote controlled?
With motor off, put motor in gear and go to wide open throttle. The butterfly in the carb should be wide open. If it isn't you need to do a link and sync.
