turbo930ss
- Aug 21, 2010
- 9
I have a 2003 50 hp bigfoot that will run great when you first start it, but once it warms up it will not run. It will spudder and run very rough. At full throttle it will barely idle. Once it cools down again it will run great. I have replaced the following parts:
1: Low pressure fuel pump
2: fuel line with bulb.
3: check valve for fuel line
4: fuel quick disconnect
5: low pressure fuel filter
6: High pressure fuel filter
I need help.
Thanks
Scott
I need help.
Thanks
Scott
