vovlo penta 270 Mechanical Lifting Device question
nightmare318
ok i just got the boat 85 bayliner 1950 the lift does work but does not unlock from the bottom on the way up im thinking is missing a part any ideas? pics of want the should look like in the transom would help thanks
captmello
Re: vovlo penta 270 Mechanical Lifting Device question
there is a rod that goes from the lift arm on the h bracket on the outdrive down to the retaining pawl.
In this pic you can see the stainless sleeve that is screwed on the top of the shaft. If that sleeve is damaged or the rod is not adjusted correctly it will not unlock.
[/IMG]
is that your problem?
Welcome to iboats, btw.:)
nightmare318
yes thanks. so im missing the top part. wounder if i could make one?
Don S
Just to be sure,what are you calling the top part? A,B,or C.
attachment.php
