I just purchased this boat and had it running at home on the muffs but when i put it in the lake at first wouldnt start. I rebuilt the carbs and replaced the spark plugs and now it will start and idle. I put it into gear and it will go until i give it throttle then it dies, but when its in gear I can play with the spark adv. arm and the linkage that goes from carb to carb and every once in awhile it will pick up and run great until i let go of both.
Any help would be greatly appreciated
