Re: Surge Brakes
There are only two major components for a surge brake system. 1) The coupler (the surge unit/master cyliinder) and 2) the brake assembly on each wheel. The first thing to check should be the master cylinder fluid level. If it's empty, you may as well consider a total rebuild of the system as with no fluid, rust and scale have formed in the system and it is now junk. Total disassembly will make it evident if rebuilding or replacement is required. That includes inspection of the hydraulic lines as well. Do not replace a master cylinder and wheel cylinders without thoroughly flushing or replacing the lines or you will be doing the job again. Before you do all of this, fill the resevoir, bleed the brakes and try it. You may get lucky. It may also be that the brakes merely need adjusting. Lots of info on-line on how to do that.
Would like to add one thing.... cause this became important during my fix. (first post too, been lurking for years!)
In addition to the master cylinder, brake lines, shoes, adjustment, drum brake hardware and individual wheel cylinders, there is / are the shock(s) that compress and subsequently activate the master cylinder. The shocks, I assume contribute to the moniker of surge....
Surge brakes are a "system".
Make sure you check the functionality of the shocks. Mine were toast. Could tell cause of the "slam" when applying the brakes on the tow vehicle. Needless to say, this caused immediate excessive mechanical force, pressure on the master cylinder which blew out. I think some systems have a pressure relief valve? Took out a wheel cylinder too (found that out during bleeding after replacing the shocks and master). I rebuilt all 4 wheel cylinders as well. All is fine now! Best to you...
