why no performance with these compression #'s
keltie
this is cut and pasted from the mechanic that originally did the tests. how can we get more power. wot only 3800 rpm with 2<br />adults and around 3500 with 5 adults<br />______________________-<br />Our technicians performed a compression check on 4/23/04 and found the following #1 cylinder 145lbs #2 125lbs #3 135lbs #4 145lbs.<br /> <br />Your mechanic is correct to recommend a conversion to electronic ignition it is trouble free, however in my experience a simple yearly inspection of a conventional ignition system prevents most issues and they are fairly trouble free.<br /> <br />Using an additive like restore does have the desired effect and given the realitively good compression I'm certain it would bump up the compresssion several pounds, how ever I doubt you would notice any performance.<br />Our technicians performed a compression check on 4/23/04 and found the following #1 cylinder 145lbs #2 125lbs #3 135lbs #4 145lbs.<br /> <br />Your mechanic is correct to recommend a conversion to electronic ignition it is trouble free, however in my experience a simple yearly inspection of a conventional ignition system prevents most issues and they are fairly trouble free.<br /> <br />Using an additive like restore does have the desired effect and given the realitively good compression I'm certain it would bump up the compresssion several pounds, how ever I doubt you would notice any performance.<br /><br />He wasnt sure on the condensor in the dist and he did not do a recheck once<br />he reset the timing so im not sure. He did suggest to switch to electronic<br />ignition distributor<br /><br />so what do we do next or check next to get the performance
flashback
Re: why no performance with these compression #'s
give us a little more info such as year make model and prop size.....boat and engine size would be nice also :)
keltie
we have an 88 renkin elite with 2.5 merc and 3.0 carb. prop is a 17 and the motor was rebuilt by the previous owner. we did not know the owner and did not realize it was rebuilt till now...i know...i know ...buyer beware. need any more info?? oh yeah..boat is 17 ft open bow
