1986 evinrude 120 stering arm assy. Help
dereck_coons
I got a nasty looking steering arm really thin and rusted up top and I kinda dont even want to touch the bottom, new price is yikes $700 and I've heard that you gotta remove the powerhead to replace it. Question is are they available used and if so is it worth the work to replace it? Any advice is appreciated.
edfishing2
Re: 1986 evinrude 120 stering arm assy. Help
Major dissassembly to get this removed. Have you looked at exploded diagrams at evinrude parts.com Are you talking about item number 7 in diagram for mid section? Yes powerhead must come off.
dereck_coons
Yep Lucky number 7 it is. Motor looks to be in great shape other than this. Not much corrosion any where else. Any idea of where to get a used #7?
edfishing2
craigslist? local boat graveyard? someone on here? aluminum arm is corroded?
dereck_coons
I cant see the lower part of the arm but the bolt #13 is super rusty. The top of the arm that attaches to the power head is super super corroded. There is 1/8" play in the mounting bracket #12. So it the top of the arm steel and the lower part aluminum?
edfishing2
The #7 is cast aluminum arm attached to a steel "pipe" that is threaded on the other end to nut #13. Is #12 moving or just #7. There may be a bearing in #12 that can be serviced but I am guessing.
dereck_coons
Yeah the guy at the parts counter today said that there is a bearing pressed into #12 and if I can get the number off of the bearing maybe a bearing shop can find it but it is only available as a unit from OMC, at a couple hundred bucks. Its hard to tell that the top of the arm is aluminum as it is really really corroded. Think i just found one on Ebay, thanks for the tip.
surrender
on my 96 88 special i did not remove power head. easy job. posted with pics last year. let me see if i can find them
edfishing2
I will have to take surrenders word on that. It looked like it would have to come out the top. Sorry for misinformation.
wilde1j
See salvage yard list in Top Secret sticky file.
dereck_coons
Hey Surrender that would be great to see pictures of the operation, I also have a 1990 88 spl, and love that motor. Thanks for all the help on this guys it is appreciated.
dazk14
Ensign
+1: no need to remove powerhead. If you have a 20" shaft there is a guy on "Western Massachusetts" craigslist that has a midsection minus the power trim and brackets. He has an ad for a PT&T and a seperate ad for the lower unit, posted on 4/29/11. He'll let it go very cheap - I believe he's expecting to toss it. Can't speak of condition.
Dsage
I went to evinrude parts.com and did not see the diagrams of the parts can some one point me in the right direction with the part numbers and such.
Dsage
I looked on the Evinrude site and did not see steering parts maybe I'm looking in the wrong area or they do not have it. I need the part that connects the steering ram to the motor. Its a round bar with a small turn down. the turn down part goes on to the steering ram and the other end is threaded for adjusting. My motor turns one way all the way but when the ram moves in all the way the motor is not turned very far. It looks like I needed a longer rod but not sure.
