shane52501
- May 17, 2010
- 14
I have 1975 15hp Johnson, and I am having trouble getting it to pump water. I have checked the water pump and changed the thermostat, and it is still not pumping water. I have also blown air thorugh the system and nothing seems to be clogged. I checked the lower end and there is no water mixing with the grease, but I do have white foam coming out of the through hub exaust (prop), that appears to be water and oil mix. Any help would be greatly appreciated.
