Re: What's a good Prop for my 4.3L 220hp 18' open bow?
I want to clarify for original poster regarding the recommendation of trim tabs. Do NOT take the cheap route and purchase Smart Tabs for this boat. I am an avid wakeboarder who purchased Smart Tabs for my runabout several years ago, with all the same hoopla and promises that are still given for the product, I can attest that they do everything they are advertised to do. They also do something that is NOT advertised...they completely wash out and destroy a good clean wakeboarding wake. After much adjusting and talking to the manufacturer who was very helpful in supporting their product, I gave up and removed the Smart Tabs and went to power trim tabs...and after I learned to use them, I got my wake back. The Smart Tabs were good for skiing. They were NOT good for wakeboarding tricks.
Wakeboarders NEED their hull to sink into the water to create a nice clean wake for jumping. Therefore only adjustable power trim tabs can provide this solution (as Tail Gunner is suggesting). Run tabs down for takeoff to help holeshot accelleration, and then lift them up flat (or even higher than flat) as soon as the boat planes to allow the hull to sink and create a nice clean wake for jumping.
I also agree that a 4 or 5 blade prop will help with holeshot more than you may realize over your current 3 blade. High 5's are expensive, IMO too expensive. But a good quality brand new stinless 4 blade can be had for $300 to $350, and an aluminum 4 blade for much less. Both alternatives cost much less than a set of power trim tabs, and are substantially easier to install. I feel it's worthy of trying. But what pitch should you buy? We have no idea....
I'll echo Silvertip that "between 4500 and 5000" at top speed is WAAAY too big of a range to make a specific recommendtion. We need an exact number. I'm not sure how Tail Gunner figured out that 19 is too small without knowing your RPM? Probably based on boat weight/size, etc...and I agree that makes sense. But if you were still at at 4500 with that 19 SS you tried, then I suspect that exactly is why your holeshot was still pretty poor, and in that case a 21 or 22 would not make any sense at all. But if you were spinning 5000 with that 19?, then your holeshot should have been maximized and you certainly wouldn't want to go any lower in pitch or you'd over-rev. There is a HUGE difference in holeshot between these two RPM numbers.
To summarize, everyone is making educated guesses based on questionable data. You need to provide more accurate RPM information in order for anyone here to provide more specific recommendation of what you should do...but as a generic answer, yes trim tabs will always improve holeshot. And yes 4 and 5 blade props will ALMOST always improve holeshot...but that depends fully on your exact current 3 blade RPM, and projected your 4 blade rpm.
