Engine starts and runs fine,but noticed when on the water and running 20-30mph the voltage drops down to 10-11 volts,when in idle the volts rise to 13volts is this normal
I would check your alternator to see if it can handle a load. Most auto parts stores should be able to check it or there are loads you should be able to apply while in the boat to see if it can handle it.
