Re: Problems with Volvo D3-160
If it has a panel like a D4 or D6, you can turn the key on while holding down one of the display keys, I can't remember which one. It might be the left arrow key, but can't really remember. You hold it down for about 5 seconds and the display on the tach will change. You then scroll through till you get to the "fault codes" selection, then select it. You will be presented with SID, PID and FMI numbers which will identify the system SID128 (engine), and the pid and fmi numbers will identify the part and the failure mode indicator. Charts are available on the web if you google and route around and get the best one. I can't remember where to go for them but they are out there. These are SAE J1708 codes and the D4 and D6 will display them if you know how to work the buttons. It's not a well known function of the D series V Pentas and I'm sure the dealerships would rather you didn't know how to access the fault system without a PC diagnostic tool. It's simple to do and can tell you some things. If the fault is not occurring when you try this, you probably won't see the fault display. My guess would be that there is a communication issue on the network between the throttle and engine computers, or a crank sensor issue.
And like shrip said, it could just be a fuel supply issue, either air in fuel or restriction in supply. Air in fuel or restriction will fault for low measured rail pressure versus commanded fuel rail pressure. When the supply can't supply necessary fuel cleanly, it won't make commanded rail pressure and it needs a clean air free restriction free supply.
