1963 Johnson V4AL 15E 75hp lower unit bearing
I had to pull my lower unit. The free standing Pins that circle around the drive shaft fell out. I was wondering if there is a tool to hold the pins in place while i re-insert the drive shaft.
Or whats the easiest way to get all the pins to stay in place while i re-insert the drive shaft?
Thanks
yorab
Ensign
Re: 1963 Johnson V4AL 15E 75hp lower unit bearing
If you simply removed the lower unit from the exhaust housing, there should be no pins to fall out. Did you also disassemble the lower unit?
tx1961whaler
Thanks
Heavy grease
