Re: 3.0 mercruiser losing rpm's after warming up
Sounds like something is tightening up, or you're starving for fuel. Check the lube in the outdrive. Make sure the water pump is working. Did you do anything with the filter in the carb? Define tune-up. That could mean anything from plugs and rotor to plugs & rotor, gearlube, oil & filter, and water pump. No two dealers I've worked for define "tune-up" the same way.
