I rebuilt the lower end and water pump on a 1976 2hp Model 2602 Evinrude. I had to pull the shaft out to change the parts.
The engine has spark and good compression. Fuel filter is fine as it is a gravity feed and when I pull the line off I have fuel going into the carb
This unit sat for several years as I could not find the lower part and did not have a lot of time to pursue it.
It has sentimental value so I would like to try and get in running again
Any thoughts? I tried a replacement carb (I bought a used identical parts motor they said ran from ebay and it did not work either).
Any thoughts? Note name is Dennis - MADL stands for Master Angler DL (joke with my kids)
