I got an old Evinrude lightwin with a little fishing boat I bought. I can't find a model or seriel number anywhere on it. I found some numbers on the LH side of the engine - 202017 on the carb, 201889 on the block and 276722 on the head. It is different than any other lightwin I have seen pics of, it has a spring loaded fuel door with a rubber plug type cap and it only has one fuel knob on the front that goes from "off to 12" and it has a small primer button below the fuel knob? Any help would be appreciated!! I lubed the cylinders and cleaned out the glass fuel bowl and it started on a little spray of carb clean, but I don't want to do anymore until I know what I've got.
