Haven't started the boat in about 3 weeks.
I went yesterday and it sounded like the batter was dead. I KNEW (little voice) the battery couldnt be dead. I was thinking it has to be hydrolocked but I didnt have many tools on my. I did have the tools to get the batt off so I charged it at home then when I went today same thing.
After 2-3 seconds of cranking slow I stopped, went to get the socket for the spark plugs and I didnt have it. So I figured Id have to come back the next day and try. But before I left I tried to crank it one more time and it was slow then tried to start, ie it started turning faster and almost turned over.
So then I tried it again after pumping the throttle 3 or 4 times and it started but sounded like crap. One time it made a loud PING sound. Didnt sound like the starter/flywheel. Maybe the starter going back in?
After a min though I got it sounding normal and running smooth again. I let it warm up about 25 mins and then shut it off and checked the oil on the dipstick a few times. Not one bit of water that I can tell. No knocking or anything.
I saw how water got in. Basically I had to put plastic over the doghouse even with the boat cover because I took one of the pieces off that goes under the two seat panels so I could make a new one and wrap it in vinyl.
Its been this way for 2 months and has been fine till now. It got a hole in it. Right above the flame arrester.
The carb is green with mold already.
Is checking the dipstick good to see if water is in the oil or do I have to drain it (the oil).
Like I said I ran it for about 25 mins letting it warm up. Anything else I should do? I was thinking change the plugs and inspect the old ones. Anything else?
Should I put have the boat put in the water and see what happens when I go out and run it or should I automatically take the carb off and have it rebuilt/replaced?
Much thanks
Much thanks
