Came across a used drive hopefully for a backup .I have the upper driveshaft housing apart for a reseal. All good so far except the bearing cup in the top cap is loose and slides out . I found it when it fell out while removing the top cover. Do I now have to replace the bearing cup,roller bearing and top cover? Is this normal for the cup to be loose ?
