i just replaced my power trim motor because it had ceased, the motor runs in both switch positions but will not raise the engine, when i lift it manually the engine stays up and when i tilt down it works great but once again when i go to tilt up the motor just runs and the engine wont tilt up. do i need to bleed the system? and if i do. How? any advice will be appreciated.
