Riegfrghtl
- Jul 7, 2008
- 77
I have a 1972 Mercruiser 888 (Ford 302) with approx. 1200 hrs. Motor and outdrive both perform like they are new (knock on wood). Last year replaced cap, rotor, condensor, and points. Adjusted dwell according to Mercruiser manual specs. Getting ready to dewinterize boat and will be replacing plugs and wires. Will also check distributor parts and dwell again. I have two question that everyone on this forum may be able to help me with.
1. Once I verify dwell I want to check timing according to Merc specs. The problem I have is I cannot find any timing marks. Are they on the harmonic balancer or on a tab by the balancer? All I can find is a pointer by the balancer.
2. What is the best way to check the mechanical advance, springs, weights, etc. on my distributor which is an Autolite. All are original and have never given me any problems but due to age this isn't going to last too long. I know most if not all the internals in the Autolite are NLA. If things are bad I know I will have to replace distributor. Does anyone have a suggestion as to which one to put in a Ford 302?
Thanks in advance for help or insight anyone can give.
Tim
Tim
