Leaking power steering fluid
dlparis72
I have noticed that I have a power steering fluid leak. I noticed this Wed. that the fluid was pooled in the bilge. I ran my hand along and underneath the housing and it seems fine. I'm a little puzzled as to where the leak may be. I suspect the hose to begin with, but what else might I check? Any suggestions? Thanks
Re: Leaking power steering fluid
There is the P/S Pump.....<br />The P/S unit on the transom plate.......<br />And, the P/S Cooler mounted in the In-coming Raw Water Line........<br />Along with the Hoses in-between......
crazy charlie
snug up the lines and fittings on the p/s cooler.It will be the first thing you come to if you follow the intake hose on the lower side of the engine.Charlie
