yorab
Ensign
- Jul 6, 2002
- 958
Long post. Please bear with me.
More than 3 1/2 years into this, I've finally seen it run again! Here's a link:
http://www.flickr.com/photos/jmm741/5651463647/in/photostream
I eventually got it running relatively smoothly, but the camera battery died so no video of that. I did have a few issues though. First the minor issues.
It took many tries to get it started and I realized that I needed to hold the choke open for it to start. Even though the choke lever was set to "Choke Off", the choke was still closed. I had to manually hold open the choke arm. Should the spring over near the choke lever hold the choke open when in the "Choke Off" position? Is it normal for the engine to only start with choke off even when cold? Also, since it was getting a bit dark, I never had a chance to adjust the slow speed needles. I'll get to that next time.
Now, a big problem that I had, which required me to shut her down, was that the top of the starboard head was getting very hot. I didn't have a thermometer so I don't know exactly how hot it was. I could only touch that area for very short time. I couldn't hold my hand there for any length of time. The paint was even bubbling a bit. The bubbling thing could be from my inexperienced painting job or it could be from a too-hot condition. I did use PlastiKote Engine Enamal rated to 500 F.
I was curious to find out if any water was flowing, so I disconnected the starboard cylinder-to-water-choke hose. There was plenty of water flowing through. However, I noticed something that I thought was odd. The water was flowing from the choke to the cylinder. Shouldn't this be the other way around? That way, the choke can react to changing temperatures of the water that comes directly from the cylinders instead of reacting to water that comes directly from the inlet water tube. I'm thinking that the water is flowing in reverse. If, for instance, the water is flowing through the exhaust cover plate and then into the cylinder bank, then I would think that would cause the cylinder bank to overheat. Is this correct? The only way this could happen, I believe, is that the inlet and outlet water pipes are switched at the adapter plate. This is something that I researched for a few weeks while I was reassembling everything, but I never found a good answer. I went with what the OMC Parts Catalog shows: the shorter inlet pipe on the port side of the adapter plate and the longer outlet pipe on the starboard side. With this configuration, the water comes up the inlet water pipe, into the adapter plate and then out the "Automatic Choke Adapter Nipple" (part #39 in the diagram). It would then go directly to the hot water choke through a hose. This would lead to the situation that I previously described in which the choke reacts not to water from the cylinder but water from the inlet pipe. I'm hoping that I don't have to completely tear apart the engine again in order to switch those two pipes. I hope that the diagram is correct. Can anybody please confirm the water flow path? I can post pics of any of the parts/systems that I have talked about if anybody wants them.
