kayakndave
- Jun 22, 2004
- 46
Hello All....Here we go again! And she was running so good! Checked the fluid in my outdrive (Volvo Penta 290 single prop). About a cup of water came out, and the oil was milky. Changed the oil. Took it out, did good. Back at home, checked the fluid again, milky again, about a cup and a half of water came out, topped it off with fresh oil. Took it out again yesterday, and after running great for a couple of hours, I had problems getting it in reverse and neutral, came back in, put the boat back on the trailer. Once back, she seemed to go in reverse/neutral ok, but I noticed the milky oil all over the driveshaft boot and hoses in the upper portion of the outdrive. Checked the lower unit dipstick, and it was WAY low - none showing on the dipstick. Obviously it is leaking in this uper area somewhere, but where? Why would the outdrive oil be leaking that high up? Any thoughts before I pull the outdrive? Again, thanks for any advice!
