Rebuilt Trim Cylinder
FreeBeeTony
Last night I rebuilt my leaky Mercruiser trim cylinder. Although it was very simple, I have a question. What can I use to seal the threads on the end cap? The manual calls for some Mercruiser sealant. Can I use Indian Head sealant that you use for head bolts? If not, what should I use?
Chris1956
Re: Rebuilt Trim Cylinder
Tony, Permatex #2 is the black, thick non hardening stuff. It does a good job protecting threads from salt watter corrosion. I use it on waterpump, manifold and riser bolts. It is thick enough to affect torque readings though!
elpaso
I would use nothing. No water is going to<br />pass the o-ring.<br />I have rebuilt 200 tilt cylinders, and have never<br />seen sealer on any. Or any rust.
