Clemsontiger
- Mar 24, 2011
- 17
Just bought boat and motor after seeing a 'dry run,' of a few seconds in the previous owners yard.
In changing the impeller and foot lube I found one of the shift-rod linkage bolts had stripped out the brass fitting. The new linkage is on but it only went on by raising the lower units' shift rod to its highest position and putting the shifter in reverse. I have disassembled and redone this thing more than once and can't tell if its me or some other dummy. :facepalm:
1st post for the other problems I ran across were addressed elsewhere on this site. Thank you all for that.
