M
Maxz695
Guest
I ordered the upper crankshaft bearing fo my 1979 40 HP 2 stroke. After removing flywheel, stator, trigger, and upper baring retaining plate, and seal? will the bearing come out relatively easy, or do I need a puller for it? Engine has has ringing at WOT scince I got it going a year ago a year ago. I want to protect the Crank bearings. There is no noticeable play in the shaft itself.
