Idle question
I have a 1994 3.0 mercruiser . I think the idle speed is to high where should it be ? mine is at 900 -1000 rmps
tommays
Re: Idle question
600 to 800 rpm is a good range to keep the clunk down when shifting gears you just have to be carefull to adjust it so that it does not stall when your docking because if you get to low it will stall at the worst time<br /><br />tommays
achris
More fish than mountain goat
Re: Idle question
Book says 650+/-50 rpm in forward gear.
beezee28
Master Chief Petty Officer
Re: Idle question
achris. "in forward gear" ?? I thought idle must your prop is not turning and the engine is just turning over with no gear engage. I have a mercruiser and it idle at about 550 to about 600 rmp after the engine is warm up.
achris
Re: Idle question
beezee,<br /><br />Yes, in forward gear! with no throttle opening.<br /><br />This is from the Merc service manual.<br /><br />See 2(f), 2(g)<br /><br />
watermark.php
<br /><br />Chris.........
Rainmaker
Re: Idle question
Set the idle as low as you can. Helps with low speed manuevering. I keep mine at about 500 RPMs.
