suzukidory
- Apr 22, 2011
- 15
hi im just getting my boat ready for the season and have a problem with fuel i have changed low pressure filter and have clean fuel on the outside pipe otf the mechanical fuel pump.
i have removed the spark plugs and have good spark but no fuel to cylinder so i removed injectors and isolated power supply to coils and turned over engine i have no fuel coming into the rail feeding the injectors from the high pressure pump i dont seam to have any power to the pump and also when i turn key on i get the 2 second test buzzer and then i get the engine light flashing and 2 beeps then 4 beeps 2 beeps then 4 beeps which indicates cam positioning sensor !!!!!!!!!!!!! but would this sensor being faulty stop power to the pump could it be as simple as that ????? if i put fuel in cylinder it starts perfectly till out of fuel !!!
the engine is 2006 and has been used for 15 hours from new look s like new never been apart or messed with just in need of some expert advice from fellow owners many thanks in advance
rob
rob
