starter removal / merc. 110 elect. 9.8hp
hula777
Does the whole pull start assembly have to be removed to take off the starter motor on this relic. ?
M
Maxz695
Guest
Re: starter removal / merc. 110 elect. 9.8hp
don,t know your engine but as long as it doesn,t interfere I don,t see why you should have to remove the assembly unless it,s blocked in after you disconnect the starter
