Re: HumminBird 798ci HD Side IMaging Transducer Mount Location
View attachment 90710View attachment 90709
Any suggestions on where to mount the transducer? The instructions say it needs to be 15" away from prop with 180 degree clearance from either side of the transducer. Clearly, the drive comes in the way. What would you do?
Given that hull/drive, you are going to have to sacrifice SI on port or starboard. If you mount it between the foam pad and the drive, you might get some image, but it will be darker. Between the foam pad and the outter tab, I think the other side will be mainly dark. If you tend to put around the lake in clockwise rotation, mount on port side. If counter-clockwise, then starboard. This would be for generally deeper lakes where you are try to scan between boat and shoreline.
To get good image on both sides, it will require a second SI transducer and a splitter cable. Mount them between foam pad and outer tab. In all cases use a transducer mounting board or king starboard, so you can make position changes without drilling additional holes in transom.
