Re: Possible bad coils...not sure Johnson 85hp
The stator on that model is a two fold component. A series of small coils on both sides are the alternator whose concern is to supply AC voltage to the rectifier which converts that AC voltage to DC voltage to charge the battery.
In the extreme front and rear of the stator are two larger coils that supply approximately 300 AC volts to the powerpack, needed to energize the ignition (spark). Should the stator be leaking a sticky looking substance out of the extreme front or rear section, replace the stator regardless of whatever ohm or voltage reading you may obtain.
The rectifier can be tested easily as follows.
(Small Rectifier Description & Location)
(J. Reeves)
On most 2,3,4,6 cylinder engines, the small rectifier is located on the starboard (right) side of the engine just in front of the engines electrical wiring strip. There are a few older V4 engines that have the wiring strip on the rear portion of the engine and the rectifier would be located just under that terminal strip. The smaller horsepower engines usually have the rectifier located on the starboard side of the powerhead close to the carburetor area.
The rectifier appears to be a round object approximately one inch (1") in diameter and also about one inch (1") high. The base of it is sort of triangular in appearance and is attached to the engine with two (2) screws/bolts..... usually one screw/bolt is larger than the other. The rectifier, depending on which one your engine uses, will have either:
One Red wire, one Yellow wire, and one Yellow/Gray wire, or One Red wire, and two Yellow wires.
Note that either of the above rectifiers could have a fourth wire which would be Yellow/Blue
The coils that have cracks...... This is quite normal with those type coils. Unless you can see sparks jumping from them to ground (crank it over at night with the s/plugs removed), usually those cracks are harmless and cosmetic, in which case coating them with liquid neoprene has been known to exten their life for years.
Now, at the present time, exactly what is your engine doing, how is it acting right now?
