Hi. I ran into a problem when
reinstaling a lower unit back to the crankcase... The drive shaft doesnt line up with the hole in the crankcase, its about a half inch out,, I can still
get it in there but have to push it fairly hard.... The drive shaft isnt bent cause wen i spin it, it doesnt wable.. I noticed that the water pump housing
is a little off wich i think is causing the leg to be slightly bent (where it bolts together, one side sits a little higher.. circled in pic) Do you know
if this is allowable, or is it something i need to fix? Im worried about wearing bearings and splines. I think its been running like this for 50 years, cause i dont know what i could have
done to cause it.. I couldnt find anything on the net about it, so i thought i would ask your opinion,
