Crranks and idles fine. When you put it in gear it wants to bog out. If I let it run this way(like its about to bog out for awile and bump the choke) and slowly keep ingaugeing the throttle, it will finally catch and I can go wide open. After this point and further up the river, if I slow all the way back down to neutral. I can push the throttle wide open and it WILL NOT bog down, IT TAKES RIGHT OFF. It only happens when I first start the engine or after Its been cut off for a few minutes. I have replaced fuel lines, screen,fuel pump, and rebuilt the carbs. Whats the problem?? Need help!!
