2004 90hp johnson outboard motor 2 stroke bombadier bogging at 3000 rpms
sm2ja
I have a 2004 90hp johnson outboard motor 2 stroke bombadier. It starts and idles like a champ. Runs fine at low speed without issue. When I hit the throttle to get over 10 mphs, it bogs down. Tries to run but seems like it is not getting fuel as it goes through a speed/bog/speed/bog etc. type of action. Fuel lines were replaced, fuel replaced and the water separator replaced at the same time. Looking for any input on some things that I can try before taking it to a shop.
Thanks
boobie
Re: 2004 90hp johnson outboard motor 2 stroke bombadier bogging at 3000 rpms
Try pushing in the key switch to activeate your primer when it does this. If it picks up and goes you have some carb probs.
