Can anyone answer the following:
1. Does the all aluminum construction create any additional noise than the standard marine plywood construction?
2. Should there be a concern about the welds breaking loose since there are no bolts?
3. The rear railing is very low for unobstructed views. Should this be a safety concern, ie someone falling over the transom.
Thanks for your input
