125 force prop
ALW_78
i have a 18 ft vision bass boat with a 125 force on it what prop should i use it will only run 32 mph with the one on it and it had a 80 hp mercury on it when i bought it and it was faster if anyone can help thanks
Frank Acampora
Re: 125 force prop
Sorry, but you can not get where you are going unless you know where you started! All this to say: We need the current prop size, material, and RPM in addition to the current speed. At least. Boat weight would be nice too
jerryjerry05
Re: 125 force prop
All that and this,do a compression/spark test.Does the trim work?Is it mounted on the transom right?J
ALW_78
Re: 125 force prop
the prop is a 17p and i dont know the rpms the tac in my boat wouldnt work with the force what kind of tac do i need
