Hello,
I have a 1988 20' Four Winns with an OMC sterndrive. Last year the boat was running great until I hit a rock and now have a vibration that exists while in gear or in neutral. When I hit the rock I was at no wake speed and it stalled the engine and did enough damage that I had to replace the prop (aluminum.) As I said the vibration occurs regardless if I am in gear so I know it is not the prop or prop shaft. Yesterday I pulled the lower unit (came out easily) and couldn't see any damage to the shaft or U-joints. (Although I did find a pine needle in between the coupler and gimbal bearing.) I spun the gimbal with my hand and that didn't appear loose and spun freely. I also noticed this still had plenty of grease on it. (I replaced it 2 years ago and checked the alignment at the time which was fine.) I then started the boat with the lower unit off and the vibrations were still present.
I am planning on checking the engine timing, any other suggestions? How do I tell if the engine mounts are bad? What about the coupler could a bolt have bent or be broken? Why would I have a pine needle in their? Is there some type of gap between the flywheel and the coupler that opened up? How would I check for that?
Thanks for any help.
