Re: 77 merc 150 bogs down under load
The motor dieing as the throttle is advanced from idle is a symptom of the carbs idle mixture screw set too lean. A great idle is another symptom of the same thing. Normally the idle is a bit rough when the carbs are set properly.
Check the compression to rule out mechanical failure, and then richen up the carbs. Did you have them worked on recently or is the motor new to you?
Open the top mixture screw 1/8 turn (CCW) and see if acceleration improves. Repeat with mid carb and then bottom carb, testing acceleration after every adjustment. Eventually you will find a setting that gives good, smooth acceleration and reasonable idling.
