Powellaround
- Apr 19, 2011
- 1
I have a pair of 2001 J70PLSIS motors on a houseboat. It seems that the motors do not like to idle. They start just fine and after about 1-2 minutes they will cut out. When docking, going from forward to reverse they tend to die as well. I have cleaned out all the carbs and used the parts from the rebuild kit. Is there somewhere I can get the step by step to adjust the carbs and check timing?
Thank you
Thank you
